Image 1
Image 1
Why Have Dual Batteries In a 4WD?
Off-roading in a 4WD can take you to exciting and remote places, but having power for your gear once you reach your destination can be challenging. By incorporating a dual battery system in your vehicle, you can create a new power source for accessories while adding extra security so you’ll never get stuck with a car that won’t start.
Learn more about a dual battery system, its benefits, how it works, and all the amazing things it can power.
What Is the Purpose of a Dual Battery System?
The purpose of a 4WD dual battery system is to create a secondary battery system (in addition to the vehicle’s main battery) that can be used for external power as a source for other accessories or gear. While the primary cell starts the vehicle’s engine and powers its electrical system as the engine runs, the secondary or dual cell can power other devices and systems when the engine is off.
You can power your camping fridge, lights, or personal electronics. It’s also a popular electricity source for power tools if you’re working at a site without grid energy. It preserves the vehicle’s main starter power source so you can always start your vehicle, but turns your car into a portable power source for whatever electricity needs you have.
Why Have Dual Batteries in a 4WD?
Do you need a dual-battery 4WD? No, but it’s nice to have for myriad reasons. It allows your car to act as a power source for accessories like lights, inverters, refrigerators, and more – without draining your vehicle’s primary cell. It comes in handy during extended off-roading excursions or camping adventures.
It also preserves your central cell’s life span by reducing discharge and charge cycles, creating a disordered crystal structure within the cell and a less efficient power source. If your main battery fails, the second one can take its place as a lifesaver in emergencies, so you always have the energy to start your vehicle and get home safely. This peace of mind is priceless.
Your second cell can also leverage renewable recharge sources like solar panels. While your vehicle’s engine or the EcoFlow 800W Alternator Charger can recharge it while driving, you can also connect it to EcoFlow Portable Solar Panels like the EcoFlow 220 Bifacial Portable Solar Panel at your campsite to use the sun’s energy for a recharge cycle.
You could also connect it to rigid or flexible solar panels on your 4WD RV if you prefer that setup. Rigid panels remain in place, while flexible panels can be mounted in different configurations to charge your EV, motorhome, and more.
How Does a Dual Battery System Work?
A dual-cell system comprises more than just two batteries. Here are the necessary components:
  1. Primary Starting Battery
The main starting battery provides an initial power burst to the car’s engine, cranking the engine and turning the vehicle’s driving capabilities on.
  1. Auxillary Battery
The auxiliary battery is the dual cell that powers accessories like lights, refrigeration, communication devices, winches, and more. Auxiliary batteries are usually deep-cycle lithium batteries that provide a consistent, reliable energy supply that won’t get depleted beyond safe limits.
  1. Battery Management System (BMS)
The isolator or BMS controls the electricity flow from the main starting battery to the dual battery, so it only draws power when the engine is on and never depletes the primary starting cell. This system ensures you’ll always be able to start your engine no matter how much energy you use from your auxiliary power source.
  1. Charging Mechanism
The vehicle’s alternator turns on when the engine runs, creating electricity and sending it to both batteries. It prioritises the main battery and then switches to charging the auxiliary cell once the main one is sufficiently charged.
  1. Voltage Sensing
A modern 4WD dual battery may use specialised voltage-sensing technology to read the two batteries’ state of charge. When it notes the main cell’s voltage dropping below a certain threshold and indicating depletion, it will disconnect the auxiliary cell so the main cell conserves critical power.
  1. Automation
Specific systems also provide automated control over battery use and connection based on factors like voltage levels, user preferences, and engine running status. Others allow the driver to manually control which cell is used, allowing you to isolate the auxiliary cell when necessary.
What Can You Run off a Dual Battery System?
An effective dual-battery system can run standard accessories and equipment for off-road adventures, camping, construction work, and more.
  • Refrigerators or portable coolers
  • Lights, such as string lights or powerful flood lights
  • Electronic devices like phones and laptops
  • Portable AC systems
  • Camping cooking equipment like coffee makers, camp stoves, etc.
  • Power tools
To determine whether your dual system can power certain accessories, add up the total energy requirement of all your gear and multiply it by the time you expect to need to run them. This should give you a measurement of watt-hours (Wh).
If your vehicle can’t handle the entire load, you can offload some of your appliances or electronics to other portable power sources, like solar generators, the EcoFlow DELTA 2 Max or the EcoFlow Smart Generator
Do You Need a Bigger Alternator for Dual Batteries?
You may need to install a bigger alternator for dual batteries if the one in your vehicle isn’t powerful enough to charge both batteries effectively. Adding a dual battery can impact an alternator’s lifespan and performance, so ensure your alternator isn’t overwhelmed and only install high-quality batteries.
Is It Worth Getting a Dual Battery for My 4WD?
To determine if a 4WD dual battery is worth it, consider the total cost, expected usage of the system, and your vehicle type. A dual battery can be a wise investment if you rely on your 4WD’s power for outdoor or camping activities. It also protects you from a vehicle that won’t start.
A dual battery system can upgrade your 4WD vehicle into a usable power source for all your accessories and gear while helping you avoid the risk of a drained battery and a car that won’t start.
These auxiliary battery systems give you additional flexibility because they can recharge through your vehicle’s alternator or alternative sources like EcoFlow Portable Solar Panels. Elevate your 4WD and your adventures with a dual battery that takes you places and keeps you powered.
Image 1
Image 1
