Image 1
Image 1
What Is a Brown Out? Causes, Effects, and How to Prepare
Ever noticed your lights flickering or your aircon losing power for a few seconds—especially during a hot summer or a wild storm? You may have experienced a brownout. But what is a brown out, exactly?
Unlike a full blackout, a brownout is when the power supply drops but doesn’t cut out completely. It’s more common than you think and can catch you off guard if you’re not prepared. In this guide, we’ll break down brown out meaning, why it happens, how it’s different from a blackout, and most importantly, what you can do to protect your home and electronics when the lights start to dim.
What Is a Brownout?
What is a brown out electricity? By definition, a power brown out is a temporary voltage drop that reduces the power supply to a facility without cutting it off completely. During a brownout, the voltage falls below the standard level, which in Australia is 230 volts. This voltage drop can cause lights to dim—hence the term “brownout”, appliances to slow down or behave erratically, and electronic devices to flicker or reset.
Brownouts can last anywhere from a few seconds to several hours. You might not even realise it’s happening at first, but if your lights are dimming or your ceiling fan starts spinning slower than usual, there’s a good chance you’re experiencing a brownout.
What Causes a Brownout?
Brownouts usually happen when there’s too much demand on the power grid and not enough supply to meet it. This often occurs during peak usage times—like during a scorching summer afternoon when everyone’s running their air conditioning at full blast. The grid gets overloaded, and to avoid a total blackout, the electricity provider might reduce the voltage temporarily to balance things out.
It can also arise from other common causes of power outages:
  • Severe weather – Storms, heatwaves, or bushfires can damage power infrastructure or increase demand suddenly.
  • Grid issues – Problems at a power station, or maintenance work on transmission lines, can reduce the electricity available.
  • Local electrical faults – Sometimes brownouts happen due to faulty wiring, overloaded circuits, or old infrastructure in your area or even your own home.
While energy companies sometimes plan brownouts (also known as voltage reductions) as a protective measure, many are unplanned and caused by sudden spikes in demand or equipment failure. Either way, knowing the signs can help you act quickly to protect your appliances and stay safe.
What’s the Difference Between a Brownout and a Blackout?
It’s easy to mix up brownouts and blackouts—they both involve power issues, but they’re quite different in how they affect your home.
When we define brownout, it is a partial loss of power characterized by a drop in voltage. You’ll still have electricity, but not at full strength. Lights might dim, appliances could slow down or flicker, and electronics might reboot or stop working properly. It’s like your home is running on “low power mode.”
A blackout, on the other hand, is a complete power outage. Everything switches off—no lights, no aircon, no internet. So, how long does power outage last? Well, blackouts usually happen suddenly and can last from a few minutes to several hours (or longer in some regional areas), depending on what caused it and how long it takes to fix.
Here’s a quick way to remember what is brownout or blackout:
Brownout = Low voltage, power still on
Blackout = No power at all
Sometimes, a brownout can rapidly escalate into a blackout if the voltage drops too low, preventing power from reaching the facility.
What Are the Effects of a Brownout?
Now that you understand the “browned out meaning”, let’s talk about its effects. Even though brownouts don’t shut off power completely, they can still cause a fair bit of trouble around the house, especially to your appliances and electronics:
  • Dimming of Lights: Incandescent light bulbs will appear dimmer during a brownout, while fluorescent and LED lights may flicker or fail to turn on.
  • Malfunctioning Equipment: Some electrical devices, such as computers, televisions, and stereos, may malfunction, shut down, or suffer damage due to the reduced voltage.
  • Overheating: Motors in appliances like refrigerators, air conditioners, and washing machines may overheat during a brownout, potentially leading to damage or reduced efficiency.
  • Data Loss: Electronic devices that rely on a steady power supply, such as computers and servers, may experience data loss or corruption during a brownout.
  • Economic Impact: Brownouts can lead to reduced productivity, equipment damage, and financial losses for businesses and industries.
Powering fridge during a brownout
What Should You Do During a Brownout?
When a brownout hits, it’s important to act quickly to protect your home and your appliances:
  • Unplug sensitive electronics – Things like computers, TVs, gaming consoles, and Wi-Fi routers are vulnerable to voltage fluctuations. It’s safest to unplug them until power stabilises.
  • Switch off major appliances – Turn off air conditioners, fridges, washing machines, and microwaves if possible. When the power returns to normal, a sudden surge could damage them or trip your circuit breakers.
  • Avoid using power-hungry devices – Try not to use high-voltage appliances like ovens or heaters until the power returns to normal.
  • Use battery-powered lights if needed – Instead of pushing your lighting system, grab a torch or use a rechargeable lamp to see clearly.
  • Stay informed – Check with your energy provider (via app or website) to see if there’s a known issue or planned brownout in your area. They’ll usually provide updates on what’s going on.
If the lights keep flickering or you’re unsure whether it’s a brownout or a more serious electrical issue, don’t hesitate to contact a licensed electrician—especially if it’s only affecting your property.
How Can You Prevent Damage from Brownouts?
While you can’t stop a brownout from happening, you can reduce the risk of damage to your home and appliances by being prepared. Here’s how to prepare for power outages and brownouts:
Use LED Lighting
LED lights are more energy-efficient and consume less power than incandescent bulbs. They also generate less heat, which can help reduce your air conditioning costs during the summer months.
Unplug Unnecessary Electronics
When not in use, unplug electronic devices to prevent them from drawing too much power and causing electrical surges.
Install Surge Protectors
Surge protectors safeguard your electronic devices against sudden power surges that can cause damage during brownouts or blackouts. Professional electricians can install surge protection to keep your business or home running smoothly.
Install the Right Breakers
Breakers control the flow of electrical current through a circuit. Install appropriate breakers at the main panel in your facility and each circuit box to prevent overloading and potential damage.
Install a Smart Power Monitor
A smart power monitoring system can alert you when voltage levels drop. It’s a great way to catch a brownout early, even if you’re not home.
Stay on Top of Electrical Maintenance
Sometimes brownouts can be caused by local wiring issues or old circuits. If you’re noticing frequent dips in power, it’s worth having a licensed electrician check things out.
Invest in Backup Power Solutions
If you want peace of mind during brownouts—or full blackouts—consider investing in a home backup generatoror more sustainably, a solar power system with storage.
A great option is the EcoFlow DELTA Pro Portable Power Station—a powerful and versatile portable home battery designed specifically for backup situations. With a massive 3.6kWh capacity (expandable up to 25kWh) and up to 7200W AC output when paired, it can handle everything from your fridge and aircon to your washing machines without breaking a sweat.
the EcoFlow DELTA Pro portable power station for home
You can integrate it directly with your home’s circuits using EcoFlow’s Smart Home Panel, which automatically switches (in just a 20ms) over during a power drop—so your essentials keep running with barely a flicker.
This portable power station charges quickly—fully recharging from a standard wall outlet in under 2 hours—and supports fast solar charging, making it a great sustainable backup option. You can monitor and control your setup easily via the EcoFlow app, giving you full visibility and custom control over your household energy use.
EcoFlow DELTA Pro home solar system
Now that you know what a brown out is and how it can affect your home, you’re in a better spot to handle one if it happens. While brownouts might not be as dramatic as blackouts, they can still wreak havoc on your electronics and daily routines if you’re not ready for them. By understanding the warning signs, taking a few simple precautions, and knowing what to do when a brownout hits, you can keep your household safe and stress-free.
Should I unplug my fridge during a brownout?
It is generally recommended to unplug your fridge during a brownout to protect the compressor and other electronic components from any potential damage caused by voltage fluctuations. However, keep in mind that your fridge will remain cold for several hours if you minimize opening the door, so your food should stay safe during short brownouts.
How do I know if I’m in a brown out?
You can tell you’re experiencing a brownout if you notice your lights dimming or flickering, your appliances running with less power than usual, or your electronic devices shutting off unexpectedly. In some cases, you may also hear a humming or buzzing sound coming from your electrical devices due to the reduced voltage.
Can I charge my phone in a brown out?
While you can technically charge your phone during a brownout, but it’s not always the best idea. Because the voltage is lower than normal, your charger might not work properly—or worse, it could overheat or damage your device over time. If you can, wait until the power stabilises or use a power bank or portable power station instead. If you do need to charge during a brownout, keep an eye on your charger and unplug it if anything seems off.
Image 1
Image 1
