7 Best Camping Generators in 2024
Embarking on outdoor adventures across Australia’s diverse landscapes calls for reliable and sustainable off-grid power.
Solar generators have become crucial companions for campers In 2024, offering an eco-friendly solution to meeting off-grid electricity requirements.
From rugged Outback terrains to countless tranquil beachside campsites, the right solar generator can make all the difference to your comfort and safety.
We’ve carefully selected the top 7 EcoFlow solar generators for any camping style and need.
Whether you’re bushwacking or taking part in an extensive Bush expedition, you’ll find the ideal generator for your next camping adventure here.
EcoFlow’s 7 Best Camping Generators 2023
  1. Best for Charging Personal Devices: EcoFlow River Solar Generator (PV110W)
  2. Best for Overnight Camping: RIVER 2 Solar Generator (PV110W)
  3. Best for Weekend Camping: RIVER 2 Max Solar Generator (PV160W)
  4. Best for Extended Camping Trips: RIVER 2 Pro Solar Generator (PV220W)
  5. Best for Portable Expandability: RIVER Pro Solar Generator (PV160W)
  6. Best for Caravaners: DELTA Max Solar Generator (PV160)
  7. Best for Off-Grid Living: DELTA Pro Solar Generator (PV400W)
Best for Charging Personal Devices: EcoFlow RIVER Solar Generator (PV110W)
In today’s connected world, staying powered up while exploring the outdoors is not just a convenience but often a necessity.
The EcoFlow RIVER Solar Generator (PV110W) excels in this respect, offering a convenient solution for keeping your personal devices charged.
This solar generator is a powerhouse for adventurers who need to keep smartphones, tablets, cameras, and other gadgets running.
EcoFlow River stands out for its affordability and ability to power multiple devices simultaneously, ensuring you stay connected and ready to capture every moment of your adventure.
Rapid recharge capability means spending less time tethered to a power source and more time enjoying the outdoors.
With its blend of efficiency and versatility, this generator is an essential kit for any tech-savvy camper or traveller who values connectivity and convenience.
Portable Power Station Specifications
  • Storage Capacity  (Minimum): 288Wh
  • Storage Capacity  (Maximum): 576Wh
  • AC Output: 600W total (surge 1200W)
  • Solar Charge Capacity (Maximum): 200W 10-25V DC 12A max
  • Weight: 11 lbs (5 kg)
  • Dimensions: 11.3 x 7.3 x 7.7 in (288 x 185 x 194 mm)
  • Operating Noise Level: ~60 decibels
  • Charging Options: Solar/AC/DC (Car Adapter)/USB-C
  • Battery Chemistry: Lithium-ion
  • Depth of Discharge: 100%
  • Warranty: 2 years
  • App Monitoring and Control?: Yes
Solar Panel Specifications
  • Rated Power: 110W
  • Efficiency: 22.8 %
  • Solar Cell Type: Monocrystalline
  • Weight: 8.8 lbs (4 KG)
  • Folded Dimensions: 16.5×18.9×1.0 in (42.0×48×2.5 cm)
  • Unfolded Dimensions: 16.5×70.3×1.0 in (42.0×178.5×2.5 cm)
  • Waterproof/Dustproof Rating: IP68
  • Open Circuit Voltage: 21.8 V
  • Short Circuit Current: 6.5 A
Pros
  • Rapid recharge from 0% to 80% in just 1 hour
  • Capable of powering up to 9 devices at once
  • X-Boost technology enables powering high-wattage appliances up to 1800W
  • Portable design with a sturdy handle, ideal for on-the-go lifestyles
  • Versatile charging options
Cons
  • May not be suitable for powering larger appliances for extended periods
  • Limited capacity compared to larger models
image1 2
For the overnight camper, the EcoFlow RIVER 2 Solar Generator (PV110W) is an ideal match. Its ease of use and rapid charging capability means you can focus on enjoying your camping experience instead of stressing about power management.
Perfect for powering essential devices like lights, smartphones, and small cooking appliances, this generator ensures that your overnight stays in the wilderness are comfortable and well-equipped. Its lightweight design and robust power output make it a hassle-free companion for any quick outdoor getaway.
Whether you’re stargazing in the Outback or enjoying a serene night by the ocean, this solar generator provides the convenience of home without compromising on the freedom of the great outdoors, all while ensuring your devices remain charged and ready for the next day’s adventure.
  • Storage Capacity: 256Wh
  • AC Output: 300W total (surge 600W)
  • Solar Charge Capacity (Maximum): 11-30V, 8A, 110W Max
  • Weight: 7.7 lbs (3.5 kg)
  • Dimensions: 9.6 x 8.5 x 5.7 in (245 x 214 x 142 mm)
  • Charging Options: Solar/AC/Car/USB-C Charging
  • Battery Chemistry: Lithium Iron Phosphate (LFP/LiFePO4)
  • Warranty: 5 years
Rated Power: 110W
Efficiency: 22.8 %
Pros
  • Exceptionally lightweight
  • Fast solar charging with up to 23% conversion
  • Durable and efficient LiFePO4 battery
  • Smart remote control for easy monitoring and adjustments
Cons
  • Limited capacity might require rationing power for multiple devices
  • May be insufficient for longer trips with higher power demands
The EcoFlow RIVER 2 Max Solar Generator (PV160W) is tailor-made for the weekend camper. Its robust capacity and swift charging time ensure that your weekend getaway is never hindered by power constraints.
Whether you’re at a family campsite or a remote beach, this solar generator keeps your essential devices and small appliances running smoothly. From charging phones and tablets to powering larger appliances like a portable refrigerator or a sound system, it has you covered.
The compact and lightweight design makes it an effortless addition to your camping gear, enhancing your weekend experience without the bulk.
It’s the ideal choice for those seeking a balance between portability and power capacity for a couple of days off the grid.
  • Storage Capacity: 512Wh
  • AC Output: 500W (Surge 1000W)
  • Solar Charge Capacity (Maximum): 11-50V 13A, 220W Max
  • Weight: 13.4 lbs (6.1 kg)
  • Dimensions: 10.6 x 10.2 x 7.7 in (270 x 260 x 196mm)
  • Warranty: 5 years
  • Rated Power: 160W
  • Efficiency: 21 % – 22 %
  • Weight: 12.3 lbs (5.6 KG)
  • Folded Dimensions: 26.9×16.9×1.0 in (68.5×43.0×2.5cm)
  • Unfolded Dimensions: 26.9×62.6×1.0 in (68.5×159.0×2.5 cm)
  • Open Circuit Voltage: 21.4 V
  • Short Circuit Current: 9.6 A
Pros
  • Quick recharge to full capacity in just 1 hour
  • Lightweight and travel-friendly
  • High conversion rate for fast solar charging
  • Durable LiFePO4 battery
Cons
  • Limited capacity for high-demand appliances
  • May not meet the demands of longer, off-grid excursions
image2 5
For those who love to immerse themselves in nature for extended trips, the EcoFlow RIVER 2 Pro Solar Generator (PV220W) is the perfect power companion. Its large capacity and efficienct solar input are perfect for multi-day camping excursions where reliable power is crucial.
With the ability to charge rapidly and sustain high energy demands, this generator ensures your lights, cooking appliances, and even some high-wattage appliances stay powered throughout your trip.
Its lightweight, compact design doesn’t compromise on performance, making it a convenient choice for remote campsites. This generator guarantees comfort and convenience, allowing you to extend your stay in the great outdoors without sacrificing on the luxuries of modern comforts.
Specifications
  • Warranty: 5 years
  • Rated Power: 220W Front Side/155W Rear Side
  • Efficiency: 22 % – 23 %
  • Weight: 20.9 lbs (9.5 KG)
  • Folded Dimensions: 32.3×19.7×1.3 in (82.0×50.0×3.2 cm)
  • Unfolded Dimensions: 32.3×72.2×1.0 in (82.0×183.5×2.5 cm)
  • Open Circuit Voltage: 21.8 V (Vmp 18.4 V)
  • Short Circuit Current: 13 A (lmp 12.0 A) Front Side / 8.8 A (lmp 8.4 A) Rear Side
Pros
  • High capacity is ideal for powering multiple devices over several days
  • Rapid charging, reaching full capacity in just 70 minutes
  • High solar input with fast solar charging
Cons
  • May be more power than needed for shorter camping trips
  • Slightly heavier than smaller models
The EcoFlow RIVER Pro Solar Generator (PV160W) stands out for its portable expandability, making it a top choice for campers and adventurers who might need to scale up their power supply.
This generator is ideal for those who plan for unpredictability, whether it’s extending a camping trip, adding more devices, or accommodating extra friends. Its ability to double its capacity from 720Wh to 1440Wh means you can adapt to changing power needs without the bulk of a larger unit.
Its versatility in powering a range of appliances, combined with the convenience of charging up to nine devices simultaneously, makes it a powerhouse for outdoor activities. This adaptability, coupled with its efficiency solar charging capabilities, offers you the freedom to extend your outdoor adventures without worrying about running out of power.
  • Storage Capacity (Minimum): 720Wh
  • Storage Capacity (Maximum): 1440Wh
  • AC Output: 600W (Surge 1200W)
  • Solar Charge Capacity (Maximum): 220W Max 10-25V DC 12A max
  • Weight: 16.8 lbs (7.6 kg )
  • Dimensions: 11.4 x 7.1 x 9.3 in (289 x 180 x 235mm)
  • Battery Chemistry: Lithium Ion
  • Depth of Discharge: 80%
  • Warranty: 5 years
  • Rated Power: 160W
Pros
  • Expandable capacity for growing power needs
  • Quick recharge capability
  • Can power up to 9 devices at once
  • High conversion efficiency of solar cells
Cons
  • Expanded capacity makes it bulkier compared to smaller units
Best for Caravanners: DELTA Max Solar Generator (PV160W)
The EcoFlow DELTA Max Solar Generator (PV160W) is a caravaner’s dream, blending high-capacity power with the flexibility needed for life on the road.
Ideal for those who enjoy the caravan lifestyle, this generator provides a dependable and expandable energy source that can adapt to your changing power needs.
Whether you’re powering a small fridge, air conditioning unit, or multiple devices simultaneously, the DELTA Max ensures you’re never left in the dark. Its rapid charging capabilities mean less time tethered to a power source and more time left for exploring.
The ability to connect with solar panels also offers caravaners the freedom to harness natural energy, further enhancing the eco-friendly aspect of their lifestyle. This generator is about providing a seamless, sustainable energy solution that complements the caravaning experience.
  • Storage Capacity (Minimum): 2016 Wh
  • AC Output: 2.4kW continuous output (5kW Surge)
  • Solar Charge Capacity (Maximum): 800W Max (11-100V 13A)
  • Weight: 48 lbs  (22 kg)
  • Dimensions: 19.6 × 9.5 × 12 in (49.7 × 24.2 × 30.5 cm)
  • Operating Noise Level: ~50 decibels
  • Battery Chemistry: NCM (Nickel Cadmium)
  • Warranty: 24 months +12 (Registration for warranty extension)
  • Rated Power: 160W
Pros
  • Expansive 2-6kWh capacity
  • Fast charging capability
  • Solar charging option
  • X-Boost technology enables powering heavy-duty devices
Cons
  • Larger size and weight is less convenient for more compact travel arrangements
  • Nickel-cadmium (NCM) solar battery has significantly shorter cycle life than Li-ion and LiFePO4 options
Best for Off-Grid Camping: DELTA Pro Solar Generator (PV400W)
The EcoFlow DELTA Pro Solar Generator (PV400W) is a powerhouse, making it the ultimate choice for off-grid camping enthusiasts. With its significant expandable capacity and robust AC output, it’s designed to meet the demands of the most adventurous off-grid experiences.
Whether you’re powering a small campsite or a large RV, it ensures you have all the energy you need. Its versatility extends to powering a wide range of appliances, from fridges to power tools, making it ideal for extended stays in remote locations.
The ability to recharge in various ways, including at EV stations, offers unparalleled convenience and flexibility. The DELTA Pro isn’t just a generator but a complete off-grid solution, providing energy independence and security in even the most remote and challenging environments.
  • Storage Capacity (Minimum): 3.6kWh
  • Storage Capacity (Maximum): 25kWh
  • AC Output: 3.6kW continuous output (7.2kW Surge)
  • AC Output (Maximum): Expandable to 7.2kW continuous output (14.4 kW surge) with 2 x EcoFlow DELTA Pro + Double Voltage Hub
  • Solar Charge Capacity (Maximum): 3.2kW with 2 x EcoFlow DELTA Pro (16 x 400W Rigid Solar Panels)
  • Weight: 99 lbs (45kg)
  • Dimensions: 25 x 11.2” x 16.4” inches (63.5 x 28.4x 42cm)
  • Charging Options: Solar/AC/Car Charger/Smart Home Panel/EV Charge Station
  • Warranty: Five years (no cycle life restrictions)
  • Rated Power: 400W
  • Efficiency: 22.6 %
  • Weight: 35.3 lbs (16.0 KG)
  • Folded Dimensions: 41.7×24.4×1.0 in (105.8×62.0×2.5 cm)
  • Unfolded Dimensions: 41.7×93,1×1.0 in (105.8×236.5×2.5 cm)
  • Open CircuitVoltage: 48V (Vmp 41V)
  • Short Circuit Current: 11A (lmp 9.8 A)
Pros
  • Expansive 3.6-25kWh storage capacity
  • Powerful 3600W-7200W AC output (7200W/14400 starting watts)
  • Innovative MultiCharge feature
  • Versatile charging options, including EV station compatibility
Cons
  • Too large and heavy to be truly compact
How To Choose the Best Generator for Camping
Choosing the right generator for your camping needs is essential for enjoying a seamless off-grid experience.
Solar generators have become increasingly popular among campers because of their eco-friendly and quiet operation.
Here are some key factors to consider when choosing the best solar generator for your camping adventures:
Storage Capacity
The capacity determines how long the generator can power your devices between charges. Higher capacity is essential for powering multiple devices or longer trips, while lower capacity might suffice for shorter excursions.
The AC output of a solar generator determines which appliances you can start and run — and how many you can operate simultaneously.
Weight
The generator’s weight is a critical factor, especially if you plan to move around frequently and without the help of a car or RV. Lighter models are easier to transport and are ideal for bushwalkers or those with limited carrying capacity.
Size
Consider the physical dimensions of the generator. A compact and sleek design is preferable for camping, as it takes up less space and is easier to pack and transport.
Portability
Look for features that enhance portability, such as ergonomic handles or wheels. Portable solar generators are particularly advantageous for camping, offering ease of movement and flexibility in placement.
Charging Speed and Options
The speed at which the generator recharges and the available charging options are closely related. Faster charging times mean less downtime and easier planning to ensure power requirements are met.
Solar Efficiency
For solar generators, the efficiency of solar panels is paramount. Higher efficiency means quicker and more effective charging from the sun, which is invaluable when camping, especially when off-grid or while away for extended periods.
Durability and Weather Resistance
The generator should be durable and ideally highly weather-resistant, as camping exposes equipment to various environmental conditions. Choose a generator to fit your desired use case, and ensure it can weather the storm of your expeditions.
Are Generators Worth It for Camping?
Generators, especially solar generators, are incredibly valuable for camping. They provide a reliable power source for essential devices like smartphones, GPS, and lighting, enhancing safety and convenience alike. Solar generators have the added benefit of eco-friendliness and quiet operation, making them ideal for the best experience in nature.
Which Camping Generator Is Best?
The ideal camping generator varies based on individual needs. A compact generator with moderate power will suffice for brief, lightweight excursions. A generator with a larger capacity and robust AC output is recommended for extended off-grid camping.
Key considerations include the length of your trip, the number and type of devices you need to power, and how you plan to transport your equipment.
Looking for the Best Camping Generators? Shop EcoFlow!
If you’re in search of the perfect camping generator, our guide has explored the top options for every type of camper.
From weekend warriors to dedicated off-grid adventurers, EcoFlow offers a range of solar generators that blend portability, power, and sustainability.
Whether you need a compact power source or a robust energy solution, find your perfect match with EcoFlow.
Ready to elevate your camping experience?
Explore our collection and find the solar generator that fits your outdoor lifestyle.
Share this article
Thanks for joining us!
Please check your email.
Popular posts
RELATED POSTS
