Image 1
Image 1
10 Essential Accessories for 4WD in Australia
Exploring Australia’s rugged terrain in a 4WD requires more than a capable vehicle—it also requires essential accessories to ensure safety and comfort.
Whether navigating challenging short off-road adventures or embarking on extended outback adventures, having the right gear makes all the difference.
This article explores essential accessories, from recovery equipment to portable fridges and safety gear. These accessories will help you tackle any situation you encounter so you can enjoy your 4WD adventure to the fullest while staying safe and comfortable.
Let’s dive in so you can get out and explore.
1. Recovery Winches and Straps
We all know that when off-roading, it’s not a matter of if you get stuck but when you do. Therefore, your recovery gear is crucial for any 4WD adventure, short or long, beginner or advanced. If you find yourself stuck, you’re going to want snatch straps so one of your mates can pull you out.
If you travel alone, you need a winch with winch extension straps to pull yourself out. Don’t forget to bring a tree trunk protector to prevent damage to the trees when extracting yourself from a sticky situation. To keep everyone safe, make sure your winch and straps are rated for your load and keep everyone clear in case a strap breaks.
2. Recovery Boards
Recovery boards are optional, but they sure do make things more convenient. Sure, you can always pack a shovel and find a log or some rocks to put under your tyres if you get stuck, but having a set of recovery boards makes it super simple.
They have great traction and are designed to help you get out of the sand or mud or to use as a ramp or bridge to get across a gap. They also usually have a shovel built-in on one end that you can use to dig debris out of the way.
3. Portable Fridge
A portable fridge is always a great option for off-road travel in Australia. The EcoFlow Glacier Portable Refrigerator is the size of a regular cooler and lasts for 40 hours wirelessly on a charge. It also has a freezer compartment with a built-in icemaker on top of it. If you’re out baking in the hot summer sun, you can sit back with an ice-cold beverage and chill in style, no matter where you are.
4. Backup Battery System
If you plan on being off-road for any length of time, you are going to want a solar generator suitable for travel. The EcoFlow DELTA 2 MAX is a perfect off-road system with plenty of power to run all your devices. You can use it to recharge your portable fridge, charge your EcoFlow Wave 2 Portable AC, and provide lights, music, and whatever else you need to travel in comfort. Who says you have to sacrifice comfort for off-road adventures?
By pairing the EcoFlow 800W Alternator Charger with a DELTA portable power station, you can quickly and efficiently charge your devices while you drive without worrying about draining your 4WD battery
5. 12V Air Compressor and Tyre Repair
If you get a flat tyre, you will want some tyre repair tools to quickly get back on the road. Or, maybe you just like to let a little air pressure out of your tyres on purpose to give you a larger contact area with the ground surface for more traction.
In either case, you will need to refill those tyres again. Bringing a portable air compressor that plugs into your 12V outlet makes this quick and easy, so you can get back on the road in no time.
6. Safety Gear
Safety gear is essential when you travel in a vehicle. Preparing for the unexpected is crucial, whether on a day trip or a multi-week outback adventure. First and foremost, bring a complete first-aid kit with you. Don’t just toss some bandaids in the truck and be done with it; off-roading requires more supplies than that. Get a complete kit with gauze, medical adhesive, tensor bandages, triangle bandages for slings, and a compress for deadly bleeds. Some basic first aid training is strongly recommended.
Other good safety gear includes flares if you get stuck alone somewhere dangerous, fire starter and extinguishers, an emergency blanket in winter, sunscreen for summer, and some water purification tablets in case you get stuck and don’t have a way to boil water.
7. LED Driving Lights
These are a nice add-on for those who like to drive at night. We know how much the wildlife loves to come out at night, which can be dangerous for you and them. It’s also harder to see holes and other obstacles at night. Therefore, extra LED driving lights, in addition to your regular headlights, are strongly recommended if you plan to drive at night. This will keep you, your vehicle, and the wild critters safe.
8. Awning
Having an awning is the perfect solution for rain or sun to give you a nice, comfortable place to sit while you chill with a cold beverage from your portable fridge. Most portable awnings can be easily mounted onto your roof racks. Don’t forget to pack those camping chairs with it.
9. Portable Solar Panels
If you plan to be off-grid for over a day or two, you’ll want some EcoFlow portable solar panels to recharge your portable power station. Depending on your vehicle, you may even be able to mount flexible solar panels on it!
10. Propane Stove
Having a portable propane stove is always a great idea for cooking meals. Even if you are just going on a day trip, sitting under your awning with a freshly cooked meal and a cold drink is nice. They don’t take up much space, and you can cook right on your tailgate; there is no need for a table.
If you use an EcoFlow Smart Generator (Dual Fuel) that can run on petrol or propane, you can share your propane fuel with your cookstove.
A successful 4WD adventure in Australia hinges on more than just skill—it’s about being prepared with the right accessories. From recovery gear and safety gear to the EcoFlow DELTA Max Portable Power Station, each item on this list helps ensure your journey is safe, comfortable, and enjoyable.
Before you hit the road, make sure you’re fully equipped with these essentials to confidently handle any off-road challenge you encounter.
Image 1
Image 1
