Image 1
Image 1
5 Best Solar Generators for Fishing in 2024 Reviewed
There’s nothing more thrilling than the anticipation of snagging a fish on your line and reeling in a big one. Before you can start posing for big fish photos, you need to ensure you’ve got everything in place for a hassle-free and leisurely fishing trip.
Technically, all you need to fish is a rod and reel and a body of water. But these days, many anglers prefer to cast out in style.
If you like to use a lot of fishing gear or kit out your boat, solar generators can be the ideal solution to power many of your devices, especially when you’re far from shore.
Here are some examples:
  • Boat batteries
  • Sonar and fish finders
  • Mechanical devices used on fishing boats, like bilge pumps
  • Marine battery chargers
  • Electronic instruments like GPS
  • Electric motors for small boats, SUPs, and Kayaks
Whether you’re an ocean or freshwater angler, a solar generator can be a blessing, allowing you to save on energy costs and lower your carbon footprint.
Not to mention that fossil fuel generators are extremely noisy, pollute the environment with toxic fumes and greenhouse gases — and can scare away the fish!
We’ll cover the five best solar generators for fishing and tell you how to pick the right one.
5 Best Solar Generators for Fishing Reviewed
1. EcoFlow River 2
river 2 1024x1022 1
The EcoFlow River 2 Solar Generator is a lightweight unit perfect for any short fishing trip. Only weighing a feathery 7.7 lbs (3.5 kg), this generator is the definition of portable. The River 2 is slightly bigger than a toaster so that you can fit it in a fishing rucksack for convenience.
Despite its compact size, the battery packs a lot of power in its small unit. It comes with 256 Wh of storage capacity. With its X-Boost mode on, it can power devices and appliances up to 600W.
The River 2 can be essential for slightly longer trips or when using more devices, like powering a 200W fish finder before your trip.
It’s also quick to recharge once you’ve utilized its 256 Wh capacity. It can fully recharge in under three hours with two 110W solar panels.
Additionally, it features a thermal energy management system, which ensures the unit functions even during inclement weather, when you’ll need power the most. The EcoFlow River 2 operates in extreme cold or hot weather between 14°F to 113°F, meaning you can still draw or charge power in the worst conditions. Having a thermal energy management system is perfect for ice fishing
2. EcoFlow River 2 Max
river 2 max 1024x1022 1
Weighing only 13.4 pounds (6.1kg), the River 2 Max is still a portable unit that delivers plenty of power. In fact, it provides 1000W of power thanks to the X-Boost mode. There are not many appliances or devices you can’t power with the River 2 Max.
For example, a fish finder can use up to 200 watts. The River 2 Max can power it for up to 5 hours! If you like cooking your catch, you can use a 1000W electric frying pan. The River 2 Max can power most items you’ll use for your fishing trip.
3. EcoFlow River 2 Pro
river 2 pro 1024x1022 2
The EcoFlow River 2 Pro features a power output of up to 1600W, allowing you to power your most pressing appliances. It’ll likely handle all your fishing devices and cooking appliances like electric grills and rice cookers, perfect for camping out on the riverbank for a week during peak fishing season.
It weighs only 17.2 pounds, which is light enough to carry back and forth from your fishing location to your camping grounds.
Thanks to the patented EcoFlow X-Stream technology, it can recharge from 0% to 100% in 70 minutes using an AC wall outlet at the campground. Once it’s ready to go, several AC outlets and other ports allow you to charge many devices simultaneously.
Whether you’re cooking up the fish you’ve caught or need to charge up your electronics for the next day in the water, the EcoFlow River 2 Pro delivers what you need in a relatively compact unit.
4. EcoFlow DELTA 2
The DELTA 2 is a reliable solar generator for anglers who prefer higher capacity and power output, especially on week-long fishing trips.
You can connect up to 500W of solar panels to capture renewable energy from the sun’s rays. With 1800W of AC output, you power over 90% of your appliances and plug up to 15 devices simultaneously. If you drive up to the fishing spot in your RV, you can power your car fridge for 16 to 32 hours, an electric grill for 0.7 hours, or a fan for 30 hours.
Sometimes you may be staying in areas with low sunlight, especially when it comes to under-the-radar fishing spots. That’s why it’s crucial to have a generator with a high battery capacity. A second DELTA 2 battery lets you reach up to 2048 Wh or even hit 3040Wh when adding the DELTA Max battery.
The DELTA 2 also will last you for many years to come. With its LFP battery chemistry, you get over 3000 cycles before it reduces to 80% of its original capacity. The lifecycle equates to 10 years of daily use before its capacity reduces. Even the most avid anglers can use the DELTA 2 for over a decade, if not more.
5. EcoFlow 12V 100Ah Lithium Trolling Motor Battery
If you’re an offshore angler who needs a trolling motor battery instead of a fully-fledged solar generator, look no further.
EcoFlow’s 12V lithium battery offers exceptional lifespan and performance — and you can use a solar panel to charge it!
You can’t plug other devices into this marine battery, but you can stay SunSmart and charge your phone with EcoFlow’s wearable solar Power Hat.
It’s an affordable combo that allows you to troll with precision and keep your mobile charged so you don’t miss an opportunity to snap a pic of your big catch.
What Should I Consider When Choosing a Solar Generator for Fishing?
Solar generators keep your equipment running so that you can focus on catching more fish and living a more sustainable lifestyle.
However, not every generator on the market is suitable for fishing. Finding the right solar generator can ruin a fishing trip if you don’t choose one that fits your electrical needs. Here are the primary factors to consider.
Portability
When you’re hiking into various fishing spots, portability is crucial. You shouldn’t have to worry about being weighed down just to have everything you powered, such as your sonar fish finder, fishing scale, and other equipment.
Power Output
The power output level determines which types of devices you can charge and power on your fishing adventure. You’ll need to look at the watt specification since that is the measure of power output.
The total output must exceed the rated power of your electric needs, especially if you’re looking to run them all at once.
Battery Capacity
Solar generators can come in various battery storage capacities, so it’s essential to choose one that fits your needs for your fishing trips.
Most generators measure the battery capacity by watt-hour. The battery capacity often determines the generator’s weight and size since the battery takes up a significant portion of the unit. A larger battery capacity means you can power more devices and run them for longer.
Charging Speed
Depending on the season and region, there might be a limited number of sun hours in a day. For some anglers, limited sunlight is preferable, like for bass anglers. However, overcast skies can also impact your solar generator recharge speed.
The solar panels for most solar generators need between 5 to 8 hours of sunlight. The charging speed can also vary due to various environmental factors and the intensity of sunshine.
Fortunately, many Ecoflow Solar Generators can fully charge in just a few hours with solar energy. You can also charge using a standard AC wall outlet or car adapter for faster charging.
Number and Type of Outlets
The outlets will determine which tools or devices you can run. For example, a USB-A connection might be fine for your GPS device, but a bilge pump requires DC connections.
Comparatively, the number of outlets will dictate how many appliances or devices the solar generator can charge or power simultaneously.
Additional Features
There are plenty of additional features you’ll want to consider when looking at solar generators. A helpful feature is an LCD, which allows you to monitor how much charge remains in the generator or how much power the solar panels produce. The more advanced solar generators may have WiFi and Bluetooth compatibility allowing you to control and monitor the unit from anywhere through your smartphone device.
Some generators even offer dual-fuel capability, allowing you to use gas to cover your power needs in case you need the extra juice.
Lifecycle
A solar generator has a designated lifecycle, meaning the number of times the unit can be charged and discharged before the capacity begins to weaken. The greater the lifecycle, the longer the lifespan of the generator.
A lithium iron phosphate (LFP) battery also lasts longer than other types of batteries, like lead-acid. These batteries are also light, making them an excellent choice for anglers who favour portability.
As an avid angler, you should spend more time fishing and less time worrying about having enough power.
Whether you’re a hobbyist who fishes for a few hours or likes to go on long ten-hour-a-day deep-sea fishing trips, getting the power you need is a must.
Compare the models above and do your research with the knowledge you’ve learned, and you’ll find the perfect generator for your fishing needs.
Image 1
Image 1
