Image 1
Image 1
4 Best Portable Power Stations in Australia in 2024 Reviewed
Choosing the best portable power station requires careful consideration of your specific power needs.
Whether you’re an avid camper, a motorhome full-timer, or seeking reliable home backup power, there’s a solution to fit every need.
This guide explores a wide range of portable power stations, each uniquely designed to cater to different scenarios, from off-grid adventures to whole-home backups.
Discover how these innovative portable power stations blend portability with efficiency, ensuring you’re never left in the dark.
EcoFlow’s Top Portable Power Stations
  1. Best for Short Off-Grid Trips: EcoFlow RIVER 2 Max
  2. Best for Extended Camping Trips: EcoFlow RIVER 2 Pro
  3. Best for Entry-Level Home Backup: EcoFlow DELTA 2
  4. Best for Expandability: EcoFlow DELTA Max
  5. Best Whole Home Backup Battery Solution: EcoFlow DELTA Pro
Reliable power is essential when venturing off-grid, whether for a weekend camping trip or an exploratory hike into the Bush.
EcoFlow RIVER 2 Max is your ideal companion for these adventures. Its key strength is balancing portability with sufficient power to support your journey.
Its design caters explicitly to outdoor enthusiasts who require a blend of mobility and utility, enhancing your overall outdoor experience.
From powering small appliances to ensuring your camera and phone are always ready to capture the moment, the RIVER 2 Max is ready to fuel your experience.
Its adaptability to different charging sources — including portable solar panels — means that you can harness sustainable energy while enjoying the serenity of nature, further extending your off-grid capabilities.
Moreover, the EcoFlow RIVER 2 Max’s safety features and long-lasting battery life offer peace of mind, allowing you to focus on making the most of your time outdoors.
With this portable power station, you’re not just carrying power but the assurance of a safe, reliable, and sustainable energy source wherever you go.
Specifications
  • Storage Capacity: 512Wh
  • AC Output: 500W (Surge 1000W)
  • Solar Charge Capacity (Maximum): 11-50V 13A, 220W Max
  • Weight: 13.4 lbs (6.1 kg)
  • Dimensions: 10.6 x 10.2 x 7.7 in (270 x 260 x 196mm)
  • Operating Noise Level: ~60 decibels
  • Charging Options: Solar/AC/Car/USB-C Charging
  • Battery Chemistry: Lithium Iron Phosphate (LFP/LiFePO4)
  • Depth of Discharge: 100%
  • Warranty: 5 years
  • App Monitoring and Control?: Yes
Pros
  • Lightweight and Portable: Ideal for carrying on outdoor adventures.
  • Fast Charging Capability: Charges 0-100% in just 60 minutes.
  • Long Battery Life: With LFP battery chemistry, it offers up to 10 years of use.
  • Versatile Charging Options: AC, car, solar, and USB-C charging.
  • X-Boost Feature: Increases output to 1000W, powering up to 80% of essential appliances.
Cons
  • Limited Power for Heavy Appliances: While ideal for small appliances, it may not be suitable for larger, power-intensive devices.
For those who love the great outdoors, the EcoFlow RIVER 2 Pro is your camping game-changer.
This portable power station is designed to meet the diverse needs of outdoor enthusiasts, from charging laptops and smartphones to running demanding camping appliances like a portable refrigerator or cooktop.
EcoFlow RIVER 2 Pro stands out for its blend of substantial power capacity and portability, making it perfect for car camping where mobility and outstanding are essential.
With its swift charging capability, you can ensure that your power station is ready to go in little over an hour, allowing more time to focus on enjoying the camping experience.
Additionally, its solar charging capability offers an eco-friendly power solution and ensures that you remain connected even in remote locations. Plug-and-play charging with EcoFlow’s 220W bifacial solar panel makes off-grid electricity generation easy.
Safety and reliability are also paramount with EcoFlow RIVER 2 Pro, which is evident in its advanced LiFePO4 solar battery chemistry and advanced battery management system.
Enjoy your outdoor adventures with the peace of mind that your power source is secure and durable, ready to take on almost any off-grid adventure.
Whether it’s a weekend getaway or an extended camping trip, EcoFlow RIVER 2 Pro is your ideal camping companion.
Specifications
  • Storage Capacity: 768Wh
  • AC Output: 800W total (surge 1600W)
  • Weight: 17.2 lbs (7.8 kg)
  • Dimensions: 10.6 x 10.2 x 8.9 in (270 x 260 x 226 mm)
  • Warranty: 5 years
Pros
  • Substantial Power Output: 800W output, expandable to 1600W with X-Boost.
  • Rapid Charging Capability: Charges from 0-100% in just 70 minutes.
  • Long Battery Life and Safety: LFP battery ensures up to 10 years of use.
  • Lightweight and Portable: Weighing only 7.8kg, it’s ideal for carrying on camping trips.
Cons
  • Limited for High-Wattage Appliances: Very high-wattage items may not be supported.
EcoFlow DELTA 2 is an exceptional entry-level solution for home backup power.
From providing emergency power during outages to offering a dependable energy source for extended road trips with the family, this station’s expandable storage capacity allows users to tailor the power available to their specific needs.
EcoFlow DELTA 2’s versatility makes it a perfect fit for those new to home power solutions. It’s a practical choice for managing unexpected power interruptions, ensuring that essentials like refrigerators, microwaves, and home medical equipment stay operational.
For outdoor enthusiasts, its capability to power multiple devices simultaneously makes it an invaluable companion for home, on camping trips, or in RVs.
Its compatibility with solar panels adds an eco-friendly dimension to power consumption, allowing users to harness renewable energy sources.
The intuitive controls via the EcoFlow app offer convenience and flexibility, making it easy to manage power needs from anywhere on the go.
Specifications
  • Storage Capacity (Minimum): 1024Wh
  • Storage Capacity (Maximum): 3kWh
  • AC Output: 1.8kW continuous output (2.7kW Surge)
  • Solar Charge Capacity (Maximum): 11-60V, 15A, 500W max
  • Weight: 27 lbs (12 kg)
  • Dimensions: 15.7 x 8.3 x 11.1 in (40 x 21.1 x 28.1 cm)
  • Operating Noise Level: ~50 decibels
  • Charging Options: Solar/AC/Car Charger
  • Cycle Life: 3000 Cycles to +/-80% Capacity
  • Warranty: Five years (no cycle life restrictions)
  • Federal Solar Tax Credit Eligibility?: No
Pros
  • Expandable Capacity: Starts with 1kWh and is expandable up to 3.04kWh.
  • High Power Output: Capable of powering more than 90% of home appliances.
  • Solar Charging Capability: Efficient charging with solar panels
  • Multiple Device Charging: You can charge up to 13 devices simultaneously.
  • Long Battery Life: Durable LiFePO4 battery offers over 3000 full charge and drain cycles.
Cons
  • Additional Purchase for Maximum Capacity: Requires extra battery for full capacity.
  • Size and Weight: Less portable compared to smaller models.
Best Expandable Option: EcoFlow DELTA Max
The EcoFlow DELTA Max distinguishes itself as an affordable, expandable option for home backup power.
Its standout feature is the ability to expand from a base storage capacity of 2kWh to an impressive 6kWh, ensuring that it can scale with your power needs, whether for routine home use or during extended outages.
EcoFlow DELTA Max’s versatility is further enhanced by its multiple charging options and rapid recharge capability.
You can efficiently power up the unit in various scenarios, whether through solar panels for eco-friendly charging or via AC-powered top-ups. The potential to combine charging methods for even faster results adds another layer of convenience and efficiency.
Designed for resilience, EcoFlow DELTA Max is a robust solution for blackouts, capable of powering a wide range of home devices, including heavy-duty appliances, thanks to its high AC output capacity.
Its integration with the EcoFlow smartphone app allows for seamless monitoring and control, bringing modern technology to the forefront of home power management.
EcoFlow DELTA Max is not just an energy source; it’s an innovative, adaptable, and expandable power solution tailored for modern homes and lifestyles.
Specifications
  • Storage Capacity (Minimum): 1612 Wh
  • Storage Capacity (Maximum): 2.8 kWh
  • AC Output: 2kW total (5kW Surge)
  • Solar Charge Capacity (Maximum): 11-100V 13A, 800W Max
  • Weight: 48 lbs  (22 kg)
  • Dimensions: 19.6 × 9.5 × 12 in (49.7 × 24.2 × 30.5 cm)
  • Charging Options: Solar/AC/Car/USB-C/USB-A Charging
  • Battery Chemistry: NCM
  • Cycle Life: 500 Cycles to 80%+ Capacity
  • Warranty: 24+12 (Registration for warranty extension)
Pros
  • Highly Expandable Capacity: Starts at 2kWh and can expand up to 6kWh.
  • Fast Dual Charging Options: Offers rapid charging, including unique combinations.
  • Powerful Output: Capable of powering 99% of home devices.
  • Solar Charging Compatibility: Supports up to 800W solar input.
Cons
  • Size and Weight: With full expansion, it may become less portable
  • Nickel Cadmium battery has a significantly shorter cycle life than LiFePO4 options
Best Whole Home Solution: EcoFlow DELTA Pro
EcoFlow DELTA Pro sets a new standard in whole-home backup power, embodying the pinnacle of portable power station technology.
EcoFlow DELTA Pro is not just exceptionally powerful; it’s a groundbreaking innovation designed for comprehensive home energy management and independence.
Its expandable capacity ranges from 3.6kWh to an extraordinary 25kWh, making it the most robust and versatile power solution in the EcoFlow lineup.
What sets the EcoFlow DELTA Pro apart is its ability to integrate seamlessly into your home, offering not just emergency backup but also intelligent energy management.
By connecting DELTA Pro to your home wiring with the EcoFlow Smart Home Panel, you’ll significantly reduce reliance on the grid and lower electricity bills.
You can chain two DELTA Pros together using a double-voltage hub to provide up to 25kWh of electricity storage with EcoFlow Smart Extra Batteries.
2 x EcoFlow DELTA Pros support up to 3200W of solar charging — that’s 16 x EcoFlow 400W rigid solar panels!
The DELTA Pro’s capabilities extend beyond just backup; it’s a solution for sustainable living, RV life, and even professional use, offering portability despite its substantial power. This portable power station represents emergency preparedness and marks a significant step towards energy independence and eco-friendly living.
Specifications
The EcoFlow DELTA Pro’s specifications are highly adaptable, varying based on your chosen combination of accessories and expansions. The base unit alone is formidable, but its capacity can increase to 25kWh with additional DELTA Pro Extra Batteries.
Solar Panel integration varies the solar input, and pairing units can boost AC output from 3600W to 7200W. This flexibility makes the DELTA Pro a customizable power solution tailored to diverse home energy needs.
Pros
  • Massive Expandable Capacity: Offers an unparalleled range from 3.6 kWh to 25 kWh.
  • Highly Versatile: Powers 99% of household appliances.
  • Fast and Diverse Charging Options: Includes the world’s fastest charging technology and compatibility with EV charging stations.
  • Advanced Smart Home Integration: Seamless home energy management.
Cons
  • Size and Portability: While portable, its size and weight increase with expanded capacity, potentially limiting ease of mobility.
What To Consider When Buying a Portable Power Station in Australia
When shopping for a portable power station in Australia, it’s crucial to consider various factors to find the right fit for your needs. Here are some key aspects to keep in mind:
Power Consumption Needs
Assess the wattage requirements of the devices you intend to power. Calculate their total wattage to determine the necessary output of the power station. This step ensures the station can handle your specific power demands effectively.
Use Case
Identify the primary purpose of the power station. Whether it’s for outdoor adventures like camping, emergency home backup, or professional use, each scenario demands different power capabilities and features. Choose a model that aligns with your specific usage requirements.
Consider the station’s capacity, measured in watt-hours (Wh), which indicates how long it can run your devices. Higher capacity models offer longer usage times but may be heavier and more expensive. Determine the right balance between runtime, cost, and portability for your needs.
Battery Life
The longevity of the power station’s battery is a crucial aspect. Look for the number of charge cycles it can withstand before its capacity reduces significantly. Batteries like Lithium-ion and Lithium Iron Phosphate (LiFePO4) are known for their extended lifespans and durability, making them a wise choice for long-term use.
Recharge Time
Recharge time is another vital factor, as power stations that recharge quickly reduce downtime and are invaluable during continuous usage needs. This feature is significant if you rely on the power station for frequent or prolonged periods, ensuring you’re not left without power when it matters most.
Weight and Portability
The physical size and weight of the power station are crucial, especially for use in outdoor or mobile scenarios. A lighter, more compact model is ideal for camping or traveling but may have lower capacity. Consider a unit that offers a practical balance between portability and power capacity to suit your specific situation.
Price
Price is a significant factor in the decision-making process. Portable power stations vary in cost, generally correlating with their features, capacity, and brand reputability. Set a realistic budget that reflects your needs and preferences. Remember, investing in a higher-priced model with more features and better quality can be more cost-effective in the long run.
Are Portable Power Stations Any Good?
Portable power stations are incredibly effective for a variety of uses, from outdoor activities like camping to providing backup power during outages. They offer convenience, portability, and a range of power capacities, making them a reliable source of electricity in situations where traditional power sources are unavailable or impractical.
When choosing a portable power station, consider factors like power needs, use case, capacity, battery life, recharge time, and portability.
We offer a range of solutions tailored to your needs, ensuring your portable power station is the perfect tool for the job.
Explore our diverse collection of Portable Power Stations today to find the perfect match for your lifestyle and off-grid power requirements.
Image 1
Image 1
